Transom Repair - Help
rubberduck
Ok I removed the engine block today, now just have to remove the shield then I can start to get dirty.
Here's a photo of the transom
http://i112.photobucket.com/albums/n195/rubberduck_49/BOAT_start_2009.jpg
The bulk of the wood is a double piece about the width of the bildge well. The lower right corner is severly rotted.
http://i112.photobucket.com/albums/n195/rubberduck_49/BOAT_start_2010.jpg
The middle of the transom as mentioned appears to be the beefiest with each side only having a single layer. The wood here is in good shape and does not appear to be a continuos piece with the middle.
How would you go about the repairs? I'm thinking of ripping out the middle section.
strizzy
Re: Transom Repair - Help
Well I think you should do the whole transom. It couldn’t be any easier then it is now, and you would hate to have a problem after doing any work at this point.
So I would take everything mounted on the transom off. And then proceed to cut the inner skin off along with the wood. There are many threads on doing complete transoms.
