Thrilliot
- Joined
- Jan 26, 2011
- 9
Hey guys, I have a 1982 Baja 16SS. The boat has a 1977 70hp evinrude that runs strong and will make her go 27mph all day but I recently purchase a 1982 90hp Evinrude to get more speed, because lets be honest, there's nothing better than going fast
. However I am concerned about my transom. In each corner of my engine well there are small cracks, they appear to be superficial and had been repaired at one point in time already by a previous owner. Until the weather gets nicer out (currently 27* with 13" of snow) I will not be able to prod further. My question is what is the best way to repair/reinforce the transom so the added weight/power of the new motor will not cause issues down the line. Original factory specs for the boat were a maximum horse power of 115, however the boat is 29 years old (my main reason for going with the 90 rather than the 115). I should also mention it currently has a stainless steel transom plate covering approx. 80% of the transom.
If I do cut the transom and just build a new, overly layered transom will I need to remove the cap or can I do it without removing the cap? Is this the best route to go?
The other idea my father and I had come up with was to fabricate a completely new transom plate that extended up over the top shell of the boat around the sides of the engine well. It would be mounted to the top and transom and be a complete, solid welded piece of treated/anodized aluminum (for weight/strength reasons). Has anyone ever done/attempted this before? Is this just a temporary fix?
I will post picture of the transom area and said cracks asap, but I do have some picture of the boat for you to get a basic idea of how it looks. Thanks for all your help, I know there are a lot of intelligent people on this site and I hope to get their input.
