I've read a lot of the posts on here, but am skeptical about doing this kind of work myself, especially if the repair costs are less than say $3000 for everything I need done.
I have a 97 Chris Craft Concept 170 (see pics below). The boat is 16 years old and this is the first major issues we've had with it, in short it's been a great little ski boat. For the last couple of years it has been taking in water around the transom/outdrive area. Up to a couple of weeks ago the bilge pump was keeping it emptied out, well the pump went out and is under the motor where you cannot get to it, so needless to say that forced the issue and we can't use the boat anymore until the problems are fixed. The way the engine bay and outside framing of the boat is made, there is just not much room to get around the motor and work. If I had a big square opening on both sides of the engine bay, I would probably tackle pulling the motor and drive myself, but being a semi-big guy at 230 lbs, I would have a hard time getting to all the mounting bolts to remove the engine.
I took it by a local boat and fiberglass repair shop called L&M Fiberglass here in Baytown. A quick look suggested it does need a transom. Somewhat of the main indicator is that I can lift on the outdrive by hand and watch the lower transom area flex a bit as I lift up/down. Jerry at L&M said that transom should be solid and zero movement. He gave an initial rough estimate of $800 for his work to replace the transom itself, but that would not include the remove and reinstallation of the motor and outdrive. There is a shop next door that he works with for that and unofficially he told me the guy is usually between $450-$550 for that portion.
In addition to the above, the lower unit has a crack and some chunks taken out around the propellor that I think were caused by the last guy I had touch the boat when he replaced the bent propellor shaft. Plus the skag has some chunks missing off the bottom of it from hitting underwater objects over the years. The poor little boat has taken a beating, but hopefully it will be fixed up good as almost new once she's done.
What do you guys think about the quotes above? Anyone have an idea of what a replacement lower unit for a Volvo Penta SX Cobra? Its the 4.3 Vortec motor inside and I guess the SX Cobra is an OMC cobra unit.
On with the pics...
On with the pics...
