Transom repair required for a280s/p to a290dp
unbolt 280 stuff from transom
bolt in 290 stuff to transom
no photos needed. cut-out may need to be trimmed slightly
you can also simply put the DP lower on the 280 drive if your desire is DP vs SP
I personally like the 290 drive better than the 280 because of the trim, etc.
correct, both are big-hole transom shield.
you will need the whole transom shield and PS cooler and trim pump from the 290
