craignorton
- Joined
- Jun 25, 2011
- 25
Hello. From what I've been reading there is a wealth of knowledge out there I'd like to tap into. I have a 1970 Winner boat in need of transom repair. Is it possible to remove the top half of the boat from the bottom to allow easier transom repair? Doing this seems feasible (looks like drill out a wack load of rivets and remove some fiberglass overlap in the inside) as, directly in front of the outboard motor is a cavity (part of the upper half of the boat) that creates getting to the inside of the transom almost impossible. If removing the wood from inside of the transom can't be done, are there any other options to reinforce it? I will appreciate any feedback.
Thanks
Craig
Thanks
Craig
