Transom repair
driftwood
I have a 1974 17' cobia. The plywood on the transome is rotted and starting to brek up the fiberglass where the outboard mounts. I checked it out and it looks like it would be easily removed and replaced from the inside of the boat. The question is
1. should I use marine plywood?
2. Do I need to glue to the Hull if so what type of blue would hold to the fiberglass hull
3. I plan on using 2 pieces of 3/4" do they need to be glued together?
4. should I coat the inside exposed plywood with new fiberglass cloth?
Thanks for any input high and dry till i get thias resolved
