Transom repair
Mr850i
Is it necessary to use "marine grade" plywood when replacing the transom wood on an aluminum boat?
Mr850i
Re: Transom repair
It's a 19.5' crestliner and it will be getting a 3ltr mercruiser with an alpha one out drive.
jigngrub
Re: Transom repair
No. You can use any exterior grade plywood, but the Aruco exterior grade plywood has been getting rave reviews on this forum.
Just be sure to seal it with several coats of epoxy resin to ensure a long life.
I Fish
Re: Transom repair
Kinda pricey, but I went with Coosa Board Bluewater 26. It's easy to work with, doesn't rot or absorb any water. Might be something to look into.
Cadwelder
Re: Transom repair
Post #3 nailed it......Coosa is a great product, but way too pricey for your application....
