Transom replacement & floor on 1990 kenner
crash1371
Does anyone know any tricks or loop holes to save me time and money on replacing my transom and floor on my 1990 Kenner 21 ft. center console? I am thinking about aluminum diamond plate flooring (any pros or cons?) I would appreciate any comments or ideas. thanks Tim
tashasdaddy
Re: Transom replacement & floor on 1990 kenner
cost, weight, heat, reflection, all bad.
Try SEACAST. It is a composite mix easy to mix and will replace the old plywood and fiberglass method. You will have a sturdy transom that will last a lifetime. I did mine and am very happy after seen all the time and money saved. On floor, I dont know about you but I had my floor done in fiberglass. I had fiberglass molds done with PVC tubing cutted in halves to make a rib- like reinforced structure every 2' apart. It worked perfectly and the strenght is unbelievable. Weight? about the same equivalent to plywood encapsulated in fiberglass...
