Transom Replacement
74arrowglass
Hello, I have been restoring my 1974 arrowglass tri hull for about 6 months now. I have the new transom and stringers glassed in and everything is rock solid. My question is that I noticed that in one area, the transom did not bond well with the hull when I glassed it in using the tap test. There is a small hole where my boarding ladder attaches near this area and I was thinking of just using a syrenge and injecting some more resin into the hole? Taking everything back out is absolutely out of the question as I have already spent quite a bit of money on supplies. The transom holds a 70hp johnson and the boat will always be stored indoors and never left in the water. Thanks alot!!
jcsercsa
Re: Transom Replacement
That will work !! infact i had to do the same thing !!! John
