Hi guys.
I need some guidance on replacing the transom in a "new to me" 1979 24' Searay. After searching hundreds of post I still have some questions. The motor in this boat was in need of a rebuild so after pulling it out I discovered the transom was shot. My boat ownership and experience has been outboards and inboards. This is my first IO. I have limited experience with epoxy and want to do it right. So, for what I think I know.
I'm planning on replacing the transom with marine plywood sealed with epoxy. Gluing the first piece of 3/4 to the cleaned roughed up inside of the outer skin with resin/wood flour glue. I will hold the first piece to the transom by sandwiching the new plywood between 2x4's using existing holes and some new if needed from the outside of the transom. After that dries I will repeat the process with the 2nd piece of 3/4" prepared and glued the same way. After that dries I can use 12" wide strips of biaxial (1708)? To tie the new transom to the existing bottom, gunnels etc. If I understand correctly, I should do a second pass over lapping the first by 6 inches in each direction. The second pass can be applied when the first pass is still tacky.
My questions
1. The boats deck is molded to the side of the boat. Where the deck meets the transom the space between the deck and the transom is a hair over 3/4?. I cleared that space out after several hours of saw and chisel work. I am considering plugging up the bilge ends of the openings and using the seacast product in that space. The new transom will than be attached to the boat as indicated above. Is this acceptable? The other possibility is to put the first transom piece in place in two sections. Any other options?
2. The old transom wood thickness in the bell housing area was just 1-1/2 inches. The second piece of ? was attached with staples and covered just the bell housing area, not the whole transom. Several posts I have read say the transom should be 2? for the Alpha One outdrive. Do I build it thicker than what it was?
3. The engine mounts have spots on each where it appears it was cut away to make room for the motor and were left open exposed to water. You can see some rot has occurred. Should I open them up and replace the wood or dry the area out and seal with epoxy?
I can post additional pictures. Thanks in advance for any suggestions and guidance. Please also advise on which epoxy, biaxial I should use on the project.
My questions
