williegilligan
- Joined
- Sep 3, 2008
- 9
At least it is not an OB.
Thanks Oops for the info and here is the post you requested.
I will show Transom Rot pics.
I plan to finish the season just fishing from the boat. No Tubiong or pulling.
I plan to be easy on the throttle as well.
Then my winter project will be to replace my transom with marine ply glassed in.
I learned this by spending a couple day reading all the GREAT posted info on this repair including Seacast. I choose the Ply because my transom has no slot. The transom is glassed in from the inside of the boat.
Everything else on the boat is in PERFECT CONDITION. I am a mechanic by trade and feel all the required experience needed I can pull off (Thanks TO iboats.com).
Even though there is NO CRACKS or LEAKS in the boat and outer layer fine.... I will install 4 each crossed turnbuckles attached to the engine and bolted to the stringers for safety(can't do this with OB. This will help with loading the boat and protect against the engine moving forward or back.
Thanks Oops for your input and I would be interested in your opinion on this temp bracing..
Hope I am doing this right! IIt looks like I need to change the Pic size in Photobucket...Sorry!
More Pics soon ...
