Transom Rot
cdkakes
I have a 1989 28Ft Baha Cruiser Fisherman with twin 302 fords. Next spring I am due for a survey and noticed this spring that the bottom of my transom is rotting. Can I remove the rotted section of my transom and replace it, or do I have to replace the whole thing to be survey ready?
PFalcon
Re: Transom Rot
There are true experts here and I know they will give you a definitive answer; however if it is for a survey it would be a poor surveyor to not notice and even complain on a half transom fix.
The transom is the second most important structural element in your hull, second to the keel, I would say replace it completely and do it with a serious eye to detail.
You can learn everything you need to know how to do it throughout these forums!
PF
cdkakes
Re: Transom Rot
So it is up to the surveyor to decide if it is adequate. There isn't a set rule that boat restorers go by?
PFalcon
Re: Transom Rot
From my readings here (note: I did not say expertise)
Rot will continue if you do not remove every single spot.
Best fix replace it all.
Second Best patch it but remember it is a structural repair, and must be treated as such. i.e.:
  • Do not miss any rotted areas.
  • Prep the area completely.
  • Use a Lap/Scarf joint in your Underlayment.
  • Professionally seal and complete the repair to be as good, or better than it was from the factory.
Good luck, remember you will be responsible for the lives you take into your vessel, and whether the survey is for you or to sell it, you want to KNOW whomever is in that vessel is safe.
PF
erikgreen
Re: Transom Rot
Hmm.. I was gonna post a reply, but Falcon said it all :)
danond
Re: Transom Rot
I have yet to see a patch job that was any easier than a full replacement. Once you're in there, you should do the whole thing.
Patched transoms function just fine, but there's little point to them, in my opinion.
Rot lives as much as 10-12 inches into (what appears to be) good wood. Once it starts, you need to replace the whole piece. If you only replace the rotted sections, you're almost guaranteed to be in there again later.
