Re: Transom Rot??
Joe38,<br /><br />I'm thinking your boat is fiberglass. If so, I would try to save what I have.<br /><br />To dry it out you'll need to get that water out of there. Find out how far the wood extends down the transom to the bottom of the hull. At the point where the wood ends, drill a couple of small holes 1/8" or smaller at the lowest point. (You may be able to do this inside the hull and let the water drain into the bilge.) This will allow the water to drain. It may take a couple of weeks. These holes can them be easily fixed with body putty or gel coat.<br /><br />Once dry, start poking around looking for the firmness of the wood. Also, be looking for the source of the moisture. You just might be able to save it. <br /><br />I had to do this very procedure on two Whaler Montauks. There were a couple of model years that cracks in the floor would allow water into the foam. These boats took almost two weeks for the water to stop dripping.<br /><br />Good Luck, let us know.
