Re: Transom saver question
Power tilt/trim makes it easier to use the transom saver you specified. But if it is really adjustable you should be able to adjust the saver length to use it with your motor. If the predrilled holes are not in the right place you could just drill another where it is needed.
P.S. There is a difference between power tilt and power trim. I had a boat (Merc OB) that had power tilt, but not power trim. The motor would tilt up and down electrically, but it the engine RPM got over a certain amount, the tilt mechanism was disabled. You could adjust the trim electrically with the motor at idle, but not at speed. Seemed kinda strange to me at first. If you have power tilt, why not power trim. I figure doing it that way lets the manufacturer size the tilt system smaller since it doesn't have to move the engine against the prop load (i.e. when trimming bow up).
The reason it did as it did as the tilt is made for low compressive forces like those beaching a boat or idling along. A trim is made to move the tilt of the engine at full thrust. Obviously it takes a lot more hydraulic "force" (piston area x hydraulic pressure) to accomplish that.
Recollecting the tilt days on OMC, as I recall, you could manually (lift) an engine with a tilt and not a trim as it was powered up and down whereas tilt was only powered up making the adaptation to a transom saver a bad idea.
My current boat has PTT and had a TS on it when I bought it. I fooled with it a couple of outings and just took it off as it was a pain....... I can see my engine from my rear view mirror; my trim is in excellent shape. I don't need it and will not fool with it. Only time I had one was with no PTT, or tilt and and OB's and an I/O that only had tilt. After I started exclusively buying PTT engines I never used it, back to the late '70's, Merc 85 with the twin cylinders mounted outboard on the tilt bracket.
Mark
