Last year I got a new trailer for my boat and The transom saver that I used for my old trailer would not fit on the new trailer. The new trailer is a Wesco aluminum I-beam trailer and the actual trailer frame is about 3 feet from the back of the boat. The bunks are extended out past the trailer frame so the boat is still supported well but the frame that I have to connect the transom saver to is way under the boat. Do any of you have a solution or idea for supporting my boat engine because I am about to trailer it 900 miles in a month and my engine needs to be supported? I think a 48" transom saver would work but the engine seems like it would still be a little too close to the road for my comfort. Is there a transom saver that is longer then 48" available? Do any of you have a saltwater boat trailer like mine? If so, how have you solved your problem of engine support on these types of trailers?
