GiMLit
- Joined
- Jul 27, 2007
- 194
Hi guys
What I am working on:
1977 18.6 ft Cobia Bowrider I/O OMC Stringer
repower from 1977 120 hp 4cyl with electric shift to a 1981 OMC 3.8 l V6 and a 800 series outdrive.
Additional facts ......... transom hole...... 16 screw boot on original (offset to port side on original setup) and 22 screw boot on new setup with centered hole and larger.
Question:
Obviously I have to cut out transom hole to fit larger boot and to bring it to center. I have done a mock setup and beleive I have it correctly positioned. Before I go crazy with the sawzall I have 1 question.
It appears that I will only have to trim out the Starboard side of the transom to accomodate the boot, based on my height being correct. I currently have the
AV plate located ***1/2 inch below the lowest portion of the transom***.
I do have hydraulic trim mounts but I want to start at the best neutral position I can.
Is the 1/2 inch below keel height too low, too high ? or can I go with that?
What would you suggest is my measurement window? 1 inch above to 1 inch below ???
Thanks as always for your opinions.
GiMLit
Question:
GiMLit
