Transom shield BIG orings
bobvonryan
I am almost ready to put my rebuilt 350 Chevy back into my boat with an AQ290 with DP. My question is I can see one oring since it was on the back of the intermediate housing when I pulled the engine. I can't see the second one. I did not pull the outdrive, I only pulled the gearbox. The plate with the six bolt holes through it does not appear to fit out the back of the outdrive so I can't see behind it. The outside oring is probably behind it. Do I need to grease both of these orings (inside and outside) when I put the motor back in or just the one on the inside? If both need greasing, how do I get the plate off to clean and grease? Also, do I need to seal the 6 bolts with anything (silicon, grease etc.) when I put them in? Thanks!:D
Don S
Re: Transom shield BIG orings
It does, put the drive down, and move the helmet out of the way, and move the ring.
I have problems with them falling out.
bobvonryan
Thanks Don! Do I need to take the water pickup hose off too?
