Transom started
dolluper
Well I finally bite the bullet and started the project it is a learning experience check it out<br /> Transom repair<br />Click on pictures for slideshow and my doopy comentary
Twidget
Re: Transom started
It looks like you will be busy for a while. Good luck and keep us posted, dopy commentary and all. :)
Mark42
Re: Transom started
Don't worry about the comentary. You can always re-work it later. <br /><br />More important is how will you fix it? Plywood and 'glass? It looks like you can't do one of those pour jobs like Seacast, right? How do you fit in the plywood and 'glas and get the deck/liner reinstalled before everything sets? I ask because it looks like the outer half of the transom is the hull and the inner half is the deck/liner. I don't understand how they got the plywood to stick to the hull and liner at once when they are two separate pieces. Know what I mean?
dolluper
Re: Transom started
Mark the inside glass of the transom was glassed to the deck at the splashwell I had to cut the glass on the transom around the splashwell to seperate the deck and hull it is a shoebox joint but it had a real hack fix previous a piece of ply thrown in at motor mounting and then glassed to the back of the splashwell :mad: After it was cut I was able to seperate the deck and hull There wasn't even a chance to think of seacast,Im going to cut the floor back 2 feet it's cut back only 1 foot now and hope the floation foam is dry there'once it's all cleaned up I plan on mat on hull ply ,mat,ply fill any gaps with miroballon and resin mixture then woven roving to the sides of the hull and bottom but not behind splashwell and then a final coat of mat sealing the whole transom After the floor is done and tied into the transom drop the deck back on I will have to pull the transom ahead a bit I think not sure at this point but I'm ready for it if I have to while i'm glassing the transom
