Transom stress Question
Cast-A-Way
HI All
I am still plugging away at my restore and enjoying it !
I was wondering what your thoughts were in regards to which type of set up puts more stress on the transom
I/O or Outboard ?
Thank you
tashasdaddy
Re: Transom stress Question
outboard.. the inboard, the engine is mounted to the stringers, the out drive to the engine. outboard, it is all on the transom.
Cast-A-Way
Thanks for the reply
I remember seeing a discussion on here about that and could not find it !
The reason I am asking is that I have a total of 3 layups on my new transom and it seems to be pretty strong but I am worried that once I get the engine back in it will crack.
I also have kept the original glass shells for the mounts that I hollowed out the rotten wood and cleaned, refilled with wood and glassed in with 3 layups again and was wondering if I should do another one or am I good to go ?
Robj
I would use how it was originally built as a guide and then do a little extra. Then you should be good to go.
Have a great day,
Rob.
