Wishin I was Fishin
- Joined
- Jun 21, 2007
- 46
Good morning everybody, I am in the process of laminating some marine plywood for my new transom in my tin blue fin. Got to scratching my head over the overall thickness of it. The max thickness is 1-1/2". I laminated two pieces of 5/8" plywood. obviously this does nto add up to 1-1/2". But what I was hoping is that with the glue and epoxy resin I would get close enough. Well the glue didn't give me much thickness as it turned out and now i'm wondering if I apply resin and glass will I get enough out of that to make it work ok. I'm assuming that the plywood is where most of the strength comes. Would that much epoxy/glass be detrimental to the overall strength of the transom? or should I just go get 3/4" ply and coat it? Just concerned about that becoming too thick.......
