Firebolt420
- Joined
- Aug 21, 2012
- 42
So my Checkmate MX 16 is on this trailer and it is a Snow trailer that is a roller/bunk trailer and there is no straight line to use transom straps.
My idea is to get two pieces of square tubing and insert them into these end tubes and attach a retracting set of straps on the end.
The extra pieces would be bolted or welded. My question is whether this is a good idea or if I should use a single gunwale strap or just use transom straps and let them ride over the bottom of the transom. Oh yeah those straps in the picture were from the PO and will be replaced. If I use transom straps without the extensions my next thought would be to attach the retractable straps in the same spot the old straps are hooked to.
Thanks
Thanks
