I recently purchased a 2002 Chaparral Sunesta 243 that came with a 2005 Rocket T24 all aluminum trailer. Its a relatively heavy boat, dry weight at about 4300lbs. It did not come with transom tiedown straps. The trailer bunks extend past the rear frame of the trailer about three feet and there is no tiedown hook on the trailer at all. I would need between a 5-6 ft strap to reach the trailer frame from the transom eyelets. The previous owner said the boat was so heavy that it did not need to be tied down. I typically trailer the boat about 30 miles to the lake.
In your opinions, do I need to retrofit this trailer/boat combination with tiedown straps, even if they are 5-6 ft long or is the boat truly heavy enough that they are not needed?
