Re: Transom to Hull?
Might ask a Mod to combine this transom to hull thread w/ your other 1:
Transom to hull?
PL & epoxy will work, but take longer to cure then poly resin based PB. If you use PL for any portion of the build, it needs 72hrs minimum to cure & off gas before covering it w/ resin & glass.
If you use epoxy, any further glass work will need to be epoxy based. Poly resin & gelcoat don't adhere well to epoxy. That's why eph used the epoxy to bed the transom (per his post in the other thread I linked) and then suggested PB for the stringers. Epoxy also needs time to fully cure (depending on what part B hardener you use) before you could unclamp the transom & finish it's glass work.
Good luck on your project.
Where in western WV?
