Mine is just far enough back that you can tilt the motor full up without hitting anything. My prop sits just foward of the tube ends. seams to work pretty well on these older low powered toon. The really ols steel one we had as a kid was setup the same way. the anty vent plate should be about even with the tube bottom. when its tilted to the shallow run position the waterpickup will still be submerged.
