OperativeK
- Joined
- Apr 21, 2005
- 154
http://opk.gotdns.org/hulldamage/photos/photo2.html
Well this last weekend wasn't too great but we still had some fun. Glad it didn't rip the hull wide open. The tree stump apparently pushed on the hull almost at the front of our 23ft IMP and ended up crushing the hull in the rear area. Once I got to examine the damage I found that the hull had something other than fiber matt layed inside the layers. Looks like a small void of foam. I have already began the repair process and I can't afford having this professionally done so here is how Im doing it.
I have drilled small holes the length of the damage and put toothpics through so I can see from the topside. I have drilled quarter inch holes in the top into the void that was created by the crushed foam. I am going to inject glass into the void. I have blocks with wax paper on the bottom to keep it from oozing out but hopefully enough to allow it to seep through the cracks lightly enough so that it will be nice and smooth after sanding.
After I am satified with enough glass into the void I will lay matt and glass over the top area to reinforce it.
My question is this, do you fellas think this is ok for a jimmy repair job? Is there something you might do to increase the strength of the repair other than what I have mentioned? Thanks -Mike
