Ive got a problem with my prop ventilating. Ive got a 1978merc115 on a 1964evinrude16'tri-hull, with a 13x17pitch prop. ventilation plate is approx 1" below lowest point on keel. prob loses water in hard hole shot, and in turns at speed. had prop cupped, and that helped some, but still ventilates in turns. everything short of swapping props seems like its where its supposed to be.<br /><br />this is my first tri-hull, and the first time Ive had this problem. it got me thinking about the tri-hulls in turns. wouldnt the outer 'sponsons' keep the boat from heeling into a turn, and cutting a clean turn? would they cause more of a 'skidding' turn that might move water over the prop differently than a monohull type boat, maybe causing tri-hulls to ventilate more often? Am I overthinking this, or what?
