Re: Tri-hull shallow water question
another question like "should I walk to work today?"
You don't say enough--like do you mean "shallowest to be in" to run on a plane? Idle? float? Moor?
for skinny water boaters, running aground, stirring bottom, etc. is common experience and nothing to worry about if you know what you are doing.
Talking boats <20':
Deep V's tend to require more water at low speeds; on a plane they are about all the same. the motor depth is way more the factor than hull design, although a broad flat bottom will obviously float higher than a narrow or keeled bottom.
What is advisable is largely driven by the bottom--soft mud, hard sand, rocks/stumps. We run over soft mud all the time because of low risk of damage, and are careful over hard sand (low risk of damage at low speed). Couldn't operate that way over rocks. Also mistakes can be fixed, or worsened, by tide.
You just have to learn your boat and waters by experience.
