Donald Terrell
- Joined
- Jul 17, 2004
- 69
I have a 1988 sunbird corsair which used to run great. The last four trips not great. First signs of trouble the boat would stumble when I first took off then it would barely get on plane running real bad but shooting forward like it used to run for only seconds at a time. I found my thermostat broken and replaced. I checked condition of wires, dist. cap,points, some plugs the easy ones to reach,checked water separator for water and found none. I performed a fuel pump volume test-okay. Took it out again and no go even worse. Then I rebuilt the carb, back to the lake and no go again. The boat idles and throttles up okay on the muffs. When in the water if it doesn't stall, you have to work the throttle so it doesn't stall, at WOT it's going 5 miles an hour bow up. I feel good about the carb rebuild. I looked into the carb as my wife worked the throttle and saw two streams of gas shoot out. I tried running with gas cap off. The shifter is hard to move into forward or move out of forward. I disconnected the shift cable at the lever on top of the engine and the shifter moved fine so I know there is a problem in the lower cable which is the recalled one red. Could there be such a problem in the outdrive hendering the engine from turning when in gear? Coil? I just don't know what to try next short of taking it to the shop. This boat once ran 40 mph smoothly. It seems to run good in the driveway but won't go in the water. I have a Cylmer manual. Please help someone??
Oh yeh, I tested the ESA switch, when in idle it worked and stumbled the engine but when in gear moving forward it didn't seem to make any change when depressed. I thought maybe the ESA was staying engaged so I carefully bent the arm so it wouldn't work but that didn't help either and I bent the arm back inplace.
