trigger coils 200 merc 94
shelbydriver
I tested the trigger with the ohm meter as in manual. I am not getting any readings at all. The engine barely runs. Should I replace it? & is flywheel removal necessary to do this? 200 merc 94 carbed v6 Any one Near Orlando, FL that does repairs (flywheel removal) or sells parts cheap?<br />Thanks in advance.
graddy
Re: trigger coils 200 merc 94
yes you do have to remove the flywheel to replace the trigger. You should have 3 to 5 volts comeing out of the the trigger when cranking and disconnected from the switch box.. The manual will not tell you that. Test with volt meter.
shelbydriver
thanks, I was checking with ohm meter as per manual. I will try that test.
shelbydriver
where do I find a dva meter as per the merc clymer & seloc manuals.
graddy
DVA is a direct voltage adapter harness. It so you can test voltages while the engine is running.
Hooty
Oops,<br />That didn't work. <br /><br />c/6<br /><br />Hooty
kenimpzoom
Just use regular multimeter on AC volts and multiply readings by 1.4.<br /><br />Ken
