Re: Trigger Magnet and Alignment Need Help
The little white mark was put in the flywheel when it was manufactured. This has to line up with half moon notch. What I would recommend you doing is clean up both the ID of the the magnet and the OD of the flywheel where it goes. Then go to a BRP dlr and get a flywheel magnet adhesive kit and put them back together .Part # 431929. When installing make sure the white mark and half moon line up. After lettting epoxy set up , re-install flywheel and check WOT timing. . Hope this helps. One other thing , Make sure the half moon on the ring is facing UP when the flywheel is installed. Has to go right next to the white mark.
