Trigger on 1150 straight 6 (and others) - how it works?
Aust1150
Just looking to fulfil my curiosity about my possible dead trigger on my 1150.
I believe thanks to smart people in this forum...
Hall Effect induces current in a pick up coil from a field generating coil with a 6 slot chopping disk in between. 3 wires back to switch box.
Has anyone opened up a dead one of these to know which wire does what?
Is there any useful continuity test information to be found by putting a meter over any pair of the 3 wires?
Are we dealing with an AC current in the pickup coil and if so (big 'if' - cause i have no idea), how is it converted into a switchbox trigger, (or does the switchbox take the trigger as AC and convert it)?
Just curious.
ps. My interest arises from previous discussion on older thread...
http://forums.iboats.com/showthread.php?t=233885
Laddies
Banned
Re: Trigger on 1150 straight 6 (and others) - how it works?
Here is how Mercury Marine explains how the system operates, if you want a technical wiring diagram for the system I can provide one for you.
