newuserguy
- Joined
- Mar 18, 2006
- 55
OK,
I have replaced the stator, trigger, rectifier, new water pump, fuel pump rebuilt and carbs rebuilt. Starts OK, However it has a serious, intermittent miss, and it is intermittent and not constant in any chronilogical sequence. It is not fuel related, stator checks out. I have been advised by a tech rep for Merc that if the trigger has any verticle movement (up and down play) it will give that kind of a miss. I pulled the flywheel and used my hand to move the trigger up and down. Yes, there is slight movement, However, I think that when the flyewheel is installed it would hold the trigger down so that it could not move vertically. Additionally, the trigger is 3 small coils fired by the hub magnet on the flywheel and I don't see why a very slight verticle movement would have any effect. Any ideas out there? Thanks for the help. Oh yes, the compression is great (140,140,138) with little leakdown loss and the plugs are new.
