Re: triggers on stator
First, do yourself a favor and obtain a service manual for your specific engine. Without it you will get yourself into more trouble than you bargained for. As Joe said, when you ask for advice, it would be nice to know what engine you are talking about (year, make, model, HP).<br /><br />The nut that holds the flywheel on is generally right-hand thread. To remove the flywheel you need a puller. It is held to the crankshaft via taper-fit and a key. DO NOT beat on the flywheel with a hammer and do not use a jaw-type gear puller. Pull the flywheel using the threaded holes near the hub.
