Triim problems if you can help?
paulm3535
I have tested the trim motor and it works. I have tested to see if the relays were getting volts. No luck there. I traced the lines to try and find the fuse and can not find it. Can any body please tell me where this fuse is located? I bought the boat used and have no manuals yet. I ordered one and I'm waiting for it to come in. I am very stuck on this one. This if for a 1992 Fourwinns Sundowner 5.0 engine I/O Cobra.
Thank you
Boatin Bob
Re: Triim problems if you can help?
Pretty sure 92's have the 50 amp breakers instead of fuses. Look near the rear up top on the engine there should be 2 breakers near the slave solenoid, one is just for trim/tilt the other is pretty much for everything else. There is also a breaker on the relay module bolted right to the hydraulic pump. See this exploded view Cobra Trim Pump of the pump, item 5 is the relay/breaker asm with the breaker reset button right in the middle.
