CaptainDavidM57
- Joined
- Apr 4, 2009
- 23
Help! After two years I put my 2009 Bass Tracker 75hp Optimax motor in the water. Prior to launch I ensured that the trim and tilt reservoir (it does leak a little) was full. On land the trim and tilt raises and lowers just fine. When I launched the boat and drove off at 3 to 4 mph the trim and tilt works fine. However, when I throttled up the engine the trim and tilt would not raise. Also, if I would stop while in the water and raised the engine as soon as I gave it the throttle the engine would lower and I can’t get it to raise while throttled. I took the boat out of the water and the engine lowers and raises just fine. I raised the motor and tried to push it down with my weight and it didn’t budge.
Why won’t the engine raise under the thrust of the prop?
