Trim and Tilt Help?
phishinout
I have searched the site, but I just want to make sure that I am correct.
I have a 1986 Johnson 110hp.....just need to top of the trim/tilt fluid.
Can I use any brand trim and tilt fluid such as Mercury brand or whatever??
Or should I use some type ATF or Dexron. Thanks for the help!
Chris1956
Re: Trim and Tilt Help?
You can use any type of Outboard OEM PTT fluid. They are all Dextron III ATF anyway. You can use any automotive Dextron III ATF as well. Whatever floats your boat!
phishinout
Thanks Chris!
All taken care of.....just wanted to be sure!
