Trim and Tilt Issue
StuckInSC
Ok, this is my first post here so I apologize if this is in the wrong area. I replaced the battery in my boat today. Prior to changing the battery, the trim and tilt worked correctly. After I changed the battery, when I press the trim up, it sends the motor down and when I press the trim down, it sends the motor up. Any ideas on what went wrong or what I can do to check if I hooked up the wires to the battery incorrectly (even though I’m not exactly sure how that would have happened).
GA_Boater
Welcome.
And what drive train is having up for down and down for up issues? It isn't a steering or control problem.
You may have swapped the power wires to the TnT which is electrically isolated from the rest of the boat.
