Trim and Tilt Oil Change
Jay Theriot
Have a Johnson Javelin 85
1980 Model engine
Can someone tell me how to change the tilt and trim Oil
Just replaced trim motor and lost most of the oil
Ive never chaged the oil in it and Im not sure how its done
Thank You
Jay
rickdb1boat
Re: Trim and Tilt Oil Change
You don't need to change the oil, just make sure it full. On the back of the pump, there is a fill screw. Raise the lower unit all the way up, remove the screw and fill until it starts to come out the hole. Install the screw hand tight and run the lower unit up and down several times. Check the fluid level again, top off as nessesary and repeat the process...
Jay Theriot
Dont remember if I replied but if I didnt
Thank you for the help
I went out as soon as I read the message and put the oil in
Trim works fine
Son and I will be fishing next weekend
Thanks again
Jay
