Re: Trim and Tilt
What cuzner is referring to is the potential damage that can be caused to an IO if it is tilted beyond the trim range while the engine is running. The u-joints in the outdrive will take a beating if raised too far. The u-joints are engaged regardless of if it in neutral or not..<br /><br />Of course on an outboard if you raise the motor (specifically the water pickups) out of the water, you can damage your water pump and potentially overheat..
