Trim Circuit Breaker
4WINNATL
Hello -
Does anyone know where I can find the fuse type circuit breaker with the following part number: Bussman 19340-01p-1L BUSS MAXI. I can find them available online, but the retailers have minimum purchases of 30 units or the alternative is they are used on ebay. I only need one.
Any help would be greatly appreciated. Thank you.
dingbat
Hello -
That is an odd ball part with limited application. Might be easier to swap out the relay block to one that uses industry standard fuses
Found a couple of in electronics supply houses.
Hello -
Ayuh,..... Have you tried yer local Napa store,..??
dingbat
The issue is that manual reset fuses have been superseded with auto reset.
The exact replacement is special order, this the min order requirement.
No reason it couldn’t be replaced with the auto reset version or even a common Maxi buss fuse
Ayuh,..... Gotcha,...... I was thinking an auto-reset breaker that fits into most standard or maxi- size fuse holders,....
The ones I've got are 1/4", or 3/8" spade connections,.....
