Trim Cylinder Cap Off - What's Next?
Woodnaut
The trim cylinder cap was removed with a pin wrench. What's next? Should the trim cylinder assembly come out or is there more disassembly required? It seems to be stuck and I do not want to force it. This is the tilt/trim unit off of a Yamaha 2006 F60TXR.
tommarvin
Ensign
Yank it out of there, was it leaking out the seal ? Do you have a rebuild kit to replace all the rubber, seals, o rings,gaskets, etc.
You are fixing the trim ram, the tilt ram is the other ram.
