Trim cylinder removal
sealyons
I am attempting to remove the trim cylinders on my '85 merc MR 200. I am having trouble removing the 2nd line from under the bell housing. The nut is starting to strip. Am I missing anything or should I keep trying?
Bt Doctur
Re: Trim cylinder removal
A "flare wrench"(line wrench) would be helpful.
Penetrating Oil will Help,..........<br /><br />After you strip the flats off the nut,..... Switch to Vise-Grips.............<br /><br />BTW,........ You'll be Needing New Lines.........
rodbolt
I usually cut the line off at the nut and use a 6 point socket on them.<br /> here in the salt pond its normal.
