MercMonster
- Joined
- Jun 3, 2007
- 151
I just got the point where I was ready to test the trim getting it set and all. I had removed the trim connector to replace both upper hydraulic cables inside the boat. When I removed the connector and installed the new hoses, I'm pretty sure without a doubt, there's a lot of air in the system. Refilled the pump with fluid and used the trailer switch and both of the arms fully extended. Was going to try the in - out method as they are "supposed" to be self bleeding, but lots of air in the line apparently. Problem is, neither one will retract. Motor runs when I hit the switch, but the arms won't retract So, I'm thinking there is air in there somewhere. I check the manual to find out how to purge air out of the system. Says to fully retract the arms, open the aft port hose, then fully extend, OK, I can't do this, arms won't retract. Would I open the forward line on the trim cylinders first to try to purge the air out that way first?? My thought was since I would have to start in reverse of what the manual suggests, this would be my open option. Is there an easier way to purge the air?
How do I get the air out of my trim lines?
