trim doesnt move up or down?
briffdogg
hi i have a larson se180 and mt trim only moves sometimes, the motor is making noise but i have to play with the 2 tubes then it will work sometimes, what can be the cause of this please?
Ayuh,.... Welcome Aboard,..... What motor,..?? What drive,..??
briffdogg
hi there thank you, its a volvo penta 4.3L drive is alpha one?. i think its the hydrolic cables that i play with then it works sometimes
briffdogg
On another note, may i ask, i forgot once to close the plug in the back to drain the water, and put the boat in the water, and alot of water filled up in the engine area maybe a third full, is it very bad? any precautions i should take or fix? everything seems fine though?
