Trim gage not working
Lake time
I have a 1985 carver 2657 5.7 murccruser alfa one gen one my trim gage is not working where is the sender and could it be out of adj what should I look for and where do I start
stonyloam
The trim sender is the round module on the starboard side of the gimbal ring. If it is the original it is a wire wound variable resistor. Go to the stern and locate the wires coming through the transom (not the trim limit which connects to b/w and p/w wires). Unplug and measure the resistance with an ohmmmeter. If it reads open the you either have a dirty contact or broken wire. If you read resistance, run the drive up and down to se if it changes. If it does then it is probably your gauge. If it reads open you can take it off and open it up to see what is wrong. You might be able to clean it and get it to work. Good luck.
I thought you had the outdrive off the boat?
Lake time
The outdrive is off but the gage hasn't worked since I got the boat in April
Lake time
I'll look in to it bud after work well the out drive is off I'm fixing all the little things on the boat well I save for the sei replacement out drive
