huntingdeer
- Joined
- Jun 21, 2012
- 117
and the plastic washer piece on both sides are missing.When are they called and ?
Hi there, Do you know what engine and drive model you have? Once we know what model you have, we'll be able to move your thread to the appropriate forum to help you fix the problem if interested.and the plastic washer piece on both sides are missing.When are they called and ?
mercruiser 5.0 alpha one 1987Hi there, Do you know what engine and drive model you have? Once we know what model you have, we'll be able to move your thread to the appropriate forum to help you fix the problem if interested.
There normally called power trim sender and limit kit.
You will need Mercruiser part number 805320A03mercruiser 5.0 alpha one 1987
Yes it works out of water.Does it work out of water? You probably need new senders but curious.
