Re: Trim gauge
Hooty, are you talking about just switching the ground wire and sender wire at the sender itself? That var. resistor will read the same resistance regardless of which wire is connected to ground and sender. If you reverse the hot/sender, grd/sender, hot/grd, all it is going to do is peg the meter in one direction or the other and not move at all. You are right about it being just a voltmeter (a very low voltage voltmeter), it actually moves off of the current flowing from ground through the sender, but even a voltmeter will not work if you wire it up backwards.
