Re: trim gauge
Adding a trim gauge requires adding the sending unit on the drive and the gauge at the helm. A single wire runs from the sender to the "S" terminal on the gauge. The gauge requires +12 volts (key on) on the "I" terminal and ground on the ground terminal. If the gauge has an internal light, the "L" terminal is wired to the NAV side of the NAV/ANC switch. Whether you actually need the gauge or not is up to you. Proper trim setting varies according to load so the guage is all but useless except to tell you whether the drive is up or down. There is no single trim setting that works for all loads and speeds.
