Hello,
I was having a bit of trouble and was hoping someone might be familiar with my problem.
I have a 1991 22' Regal bowrider with 1990 model-year 5.7L Mercruiser/Alpha One Gen I. I noticed during the season that although the drive raised fine, it seemed a little sluggish going down. The motor sounded fine, but the pump made kind of a squealing sound in the down direction. When it reached the end of travel in the down direction, there was no change in sound like it used to from the pressure. As I was preparing to winterize, it decided that it would no longer go down at all, even with someone trying to push on it, and the motor was spinning away - same "squealing" type noise. I ended up removing the rams from the drive to let it down so the bellows would not stretch over the winter.
Any thoughts on what could be wrong? I'm not sure if the issue is in the pump or trim cylinders. It's definitely not the motor because that got reeplaced last year when it died.
Thanks for any help you can give!
Jared
Jared
