trim guage adjustment?
Toby S.
I have a 1990 xp150 and installed a new trim sender. The needle jumped into possition as soon as I connected it but it is out of wack big time. Basicaly when it is all the way down it reads all the way up. Bassackwards. I wonder if when they installed the arm on the potentiometer they didn't have it turned to the proper setting.
Joe Reeves
Re: trim guage adjustment?
Toby..... Every trim gauge sender I've worked with had two wires leading from it. I suspect yours are reversed. Remove and switch them.
Toby S.
yeah, I suspected the polarity was reversed when I first turned the ignition on but when I switched them it was aparent that polarity did not matter. All the wires are colorcoded to idiot proof it that is why I suspected the pots needs a revolution in the opposing direction and then put the arm back and spring on.
Skyhigh
Rotate to gauge 180 degrees, then it will be right (I think)
